Hello, I'm looking to change the thermal paste of my gpu and i got a cooler master compound that came with my cooler master hyper 212 , would it be okay and safe to use it ?
Also I'll be using alcohol 90 for the cleaning since it's what I have at hand , that also okay ?
https://linustechtips.com/topic/1308601-thermal-paste-replacement-for-gpu/
That should be fine, for as long as the thermal paste is not electrically conductive. MX-4 or a high quality paste will be good with your graphics card. 90% isopropyl alcohol is great as the higher %, the better it is as you're not introducing any impurities/water that is found in lower percentage.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
9 minutes ago, squallypo said:
So the one I have won't be good at all ? I mean the cooler master thermal paste
It should be good that paste, as long as the tube is not old and the paste has separated into different components (oil/water), the paste should work.
In fact, any thermal paste should work fine as long as its not electrically conductive; those that I pointed out in my previous post are just thermal pastes that are the best* on the market (not including liquid metal, which is completely different and some precautions are to be taken when using it).
2 minutes ago, squallypo said:
The paste should be okay since I got the cooler like 3 months ago, and yes I will get thermal grizzly later on, but for now I wanna try this to clean my gpu since I haven't in so many years , thank you !
Ok, just know that if you use the Thermal Grizzly Conductonaut (Liquid Metal), you can't use on aluminum heatsinks.
Hydronaut and kryonaut both good right ? But as I said for time being gonna try this cooler master one
If your GPU paste hasn't been changed in a few years then probably any fresh paste would be a good idea. Thermal Grizzly Kryonaut tends to be a favorite of many people but I think you'll be happy enough with the CM paste for now.
I tried some different pastes on my CPU and GPU and have ended up with Kryonaut on my CPU and Conductonaut on my GPU. It's copper coated so aside from staining it doesn't do much damage to the heatsink
