If you're just looking to game, 16gb is a good sweet-spot as it gives you more than 8, which is getting to be the minimum requirement more and more. A decent 2x8gb kit will be sufficient, and a Ryzen 3600 runs 3200mhz as its standard RAM speed, so anything at least that fast or faster will work. What's your price range that you're looking to stay around? RGB necessary?
I use a lot of Corsair LPX and have a 2x8gb kit in my R7 2700x system next to me, and the same one in a computer at my office with an R5 1600.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1308121-help/#findComment-14501887
