Budget (including currency):
Country: Germany
Games, programs or workloads that it will be used for:
Asus ROG Strix X570-I Gaming Mainboard  + 5800x
anidees AI Crystal Cube AR V3 EATX/ATX
will it fit and work together ?
https://linustechtips.com/topic/1307518-does-it-fit-and-work/
Yes, but it's a little silly. That motherboard is really small, and that case is really big. It'll look empty, you'll pay extra for the compact size, and you'll lose out on important features like extra RAM, PCIe, and M.2/sata slots.
Just get a bigger motherboard. Maybe a good B550 instead of an X570, they tend to be better value.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1307518-does-it-fit-and-work/#findComment-14497357
it actually said motherboard compatibility mini itx but when i scroll down it says
MOTHERBOARD TYP M-ITX, M-ATX, ATX, E-ATX
does that mean i can use a standard sized ATX ?
i want to overclock my 5800x  which would u recommend my budget is like 250€
https://linustechtips.com/topic/1307518-does-it-fit-and-work/#findComment-14497666
Honestly I recommend a b-550 board for almost any overclock you could want. the Asus B550F is a good one to try. the x series boards aren't a hell of a lot more robust in my experience. Better power delivery sure but without serious cooling you won't get much done. If you plan on overclocking I would go with a b series motherboard (b550 not sure if 450 is compatible with 5000 series yet) and a beefy air cooler. Something like a noctua uh12s or a D15s should be very effective and very quiet when idling.
https://linustechtips.com/topic/1307518-does-it-fit-and-work/#findComment-14497892
