Hello I've been playing Minecraft for awhile on this pc and it was running fine untill i installed some drivers and now Minecraft and only Minecraft just doesn't want to run above 40 fps and the average is 20-30 fps while using SEUS shaders I've searched everywhere but I can not figure out a single fix and I've even tried reinstalling Opti fine I've tried to uninstall my driver and even roll back my driver but when i try to roll back the option is greyed out. I've tried to allocate more ram and that didn't help anything either I just don't understand why I'm getting such low frames on parts that shouldn't be giving me low frames
gpu:Gtx 1660 super 6gb.
cpu:ryzen 5 2600
ram:1x8gb
pw:500w
mb:ASrock A320m-hdv R4.0
https://linustechtips.com/topic/1307112-minecraft-shaders-sudden-low-fps/
Seus shaders are very GPU intensive. You can try to lower the render distance.
Also: please provide further information:
- What were your FPS before the driver update?
- what version of Seus are you using? (Ultra, high, medium, lite)
- are you sure that you dont have a FPS limit set in the video options?
- do you have enough RAM allocated to minecraft?
