How do I reinstall settings
Go to solution Solved by TheFBI,
I fixed all my problems by installing windows 10 on a vm and copping over all windows files from that
36 minutes ago, TheFBI said:
I am having issues with setting stuff like sub-windows not opining and some setting acting all messed up
If you're referring to explorer, just go to Tools/Folder Options and set to 'open each folder in its own window'. If something else, it's easier if you specify.
~ Gaming since 1980 ~
PassMark | UserBench
