what psu?
seems like there is dust or something between the fan. @jonnyGURUcan also help with this. He knows a lot.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490274
Just now, TheProGamer said:
Thank you, I’ve messaged him
nah you wouldnt needed to do that.
I tagged him, so he can see this on his activity notifications .
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490286
1 minute ago, TheProGamer said:
Also, I have the Corsair CX600
thats the green label which is meh at the best. Would wait for him tho. he can really tell if it is coil whine, FET whine, anything he can think of.
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490289
Guess we’ll wait for his input then, thanks
Console.WriteLine("Hello World!");
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490293
it can take sometime, since the guy works at Corsair. R&D if i remember right. Also different time zones etc. so go sleep, go out, or go eat etc.
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490297
It’s fine, I’ve got games to play to pass the time
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490312
1 hour ago, TheProGamer said:
Hi guys,
My power supply keeps buzzing. I’ve attached a video. Is this a serious problem or is it just an annoyance?
Thanks
FullSizeRender.mov
So you say it's the older CX600 (not a CX650) and it just started doing this?
Sure it's not the fan?  Can you stop the fan from spinning (like with a Q-tip or pencil eraser or drinking straw) to see if the noise stops?
https://linustechtips.com/topic/1306595-power-supply/#findComment-14490469
Hello,
I haven’t done any troubleshooting yet, as I had no idea how to fix it. I’ll try blocking the fan, and seeing if the noise stops. I’ll reply again once I’ve done it.
https://linustechtips.com/topic/1306595-power-supply/#findComment-14491565
4 hours ago, TheProGamer said:
Hello,
Hi again, I couldn't block the fan, but I noticed the sound goes away when I lay my computer flat on it's side (resting on the back side panel). What does this mean?
https://linustechtips.com/topic/1306595-power-supply/#findComment-14492060
33 minutes ago, jonnyGURU said:
It means it's the fan.
What shall I do then? Does it need replacing or is it just a noise? I don’t wanna have to buy a new power supply if I don’t have to.
https://linustechtips.com/topic/1306595-power-supply/#findComment-14492502
1 minute ago, jonnyGURU said:
Yeah.   PSUs don't last forever.
The fan is the first thing to go.  It's a good sign that something is going to fail next.
Time to replace the PSU.
Thanks for your help, do you have any recommendations for another PSU?
https://linustechtips.com/topic/1306595-power-supply/#findComment-14492740
