Hi,
I am about to build my pc when my case comes in - 011 xl, and I just realised my aio came with ml120 fans and not ll120 fans.. I have bought 6 ll120 fans. If I connect all 6 ll120 fans to one node pro, and the ml120 fans to another, will the fans rgb work fine? I have an x570 tomahawk mobo, will this have enough rgb ports for this?
Thankyou 😁
https://linustechtips.com/topic/1305852-fan-help/
30 minutes ago, Mattiie said:
Hi,
Thankyou 😁
Can’t speak to rgb, though I suspect the answer is “yes” because as long as there is at least one, things can be arranged. Generally controllers are powered by USB, so it doesn’t produce any stress.
https://linustechtips.com/topic/1305852-fan-help/#findComment-14484167
Thank you for the response! Fingers crossed all goes well! 😁
https://linustechtips.com/topic/1305852-fan-help/#findComment-14484252
