Just now, DriftMan said:
yeah, you should try doing some research before posting questions
yes it can be repleaced, it can also be upgraded, it uses a normal battery so you can get those in eBay, AliExpress, etc
I'd suggest upgrading to a bigger one following some guides
Okay thanks. Ima do some research hah
https://linustechtips.com/topic/1305772-anne-pro-2-battery/#findComment-14483496
