Issues connecting with cockpit to Ubuntu
Solved by Master Disaster,
Its a certificate error. From what I'm reading on GitHub it seems as though Cockpit has to be accessed through HTTPS on the browser, using HTTP won't work. I'm not sure how you can get a certificate for your loopback subdomain though? All the people who fixed this issue did so by using Apache/NGINX, obtaining a certificate using Cerbot then setting up a HTTPS reverse proxy.
One person says that adding "AllowUnencrypted = true" to "/etc/cockpit/cockpit.conf" and restarting the cockpit service allows it to work internally through HTTP but you lose external access entirely.
