need help in basic AHK
Go to solution Solved by igormp,
5 minutes ago, hirusha.adikari said:
700116451_2021-02-1122_06_27-AutoHotkeyHelp.thumb.png.93e51c124eeb956ac064360169890640.png
why do we add a ":" after the word "Taste" ??
This structure is often called a "dictionary" or "map", where you have a series of Key-Value components. In this specific case, "Taste" is the key and "Delicious" is the value.
FX6300 @ 4.2GHz | Gigabyte GA-78LMT-USB3 R2 | Hyper 212x | 3x 8GB + 1x 4GB @ 1600MHz | Gigabyte 2060 Super | Corsair CX650M | LG 43UK6520PSA
ASUS X550LN | i5 4210u | 12GB
Lenovo N23 Yoga
https://linustechtips.com/topic/1304841-need-help-in-basic-ahk/#findComment-14475966
