Budget (including currency): $2000 to $2500 CAD
Country: Canada
Games, programs or workloads that it will be used for: excessively modified minecraft at 4k 60hz; also, hoping to have fun overclocking and tweaking
Here's my ideal build (criticism welcome) and I'm hoping you folks can help me find ways to get as close to this as possible within my budget. I pretty much only play modded minecraft with any consistency but want to pick up CS:GO once I've got a decent system - the current one can barely do minecraft lowest settings at 1440p and ~40 fps. Last time I built a PC it was nearly $10k with a 480mm rad and around 15 years ago now, so I'd like to have my overclocking fun without breaking the bank this time. Thanks in advance for the help.
PCPartPicker Part List: https://pcpartpicker.com/list/VsmVgt
CPU: AMD Ryzen 7 5800X 3.8 GHz 8-Core Processor  ($528.97 @ Amazon)
CPU Cooler: Asus ROG Strix LC 360 80.95 CFM Liquid CPU Cooler  ($239.99 @ Amazon)
Motherboard: Asus ROG Crosshair VIII Hero (WI-FI) ATX AM4 Motherboard  ($449.98 @ Amazon)
Memory: Kingston HyperX Predator 32 GB (2 x 16 GB) DDR4-3600 CL17 Memory  ($269.95 @ Amazon)
Storage: Samsung 980 Pro 1 TB M.2-2280 NVME Solid State Drive  ($229.99 @ Amazon)
Video Card: Asus Radeon RX 5700 XT 8 GB STRIX GAMING OC Video Card
Case: Lian Li PC-O11 Dynamic ATX Full Tower Case  ($242.10 @ Amazon)
Power Supply: EVGA SuperNOVA GA 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($125.41 @ Amazon)
Total: $2086.39
Generated by PCPartPicker 2021-02-11 02:19 EST-0500
https://linustechtips.com/topic/1304678-help-downgrade-this-build/
Why are you looking to downgrade the build? It looks pretty solid, save maybe swapping out the 5800X for a 5900X among some other minor things
My profile picure is real. That's what I look like in real life. I'm actually a blue and white African Wild Dog.
Ryzen 9 5900X - MSI Ventus 2x OC 3060 Ti - 2x8GB Corsair Vengeance LPX 3200MHz CL16 - ASRock B550 Phantom Gaming ITX/ax
EVGA CLC 280 + 2x140mm NF-A14 - Samsung 850 EVO 500GB + WD Black SN750 1TB - Windows 11/10 - EVGA Supernova G3 1000W
CPU: AMD Ryzen 9 5900X 3.7 GHz 12-Core Processor  ($750.00)
CPU Cooler: Cooler Master MasterLiquid ML360R RGB 66.7 CFM Liquid CPU Cooler  ($107.99 @ Newegg)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard  ($192.99 @ Best Buy)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3600 CL18 Memory  ($177.99 @ Amazon)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  ($329.99 @ Amazon)
Power Supply: Corsair TXM Gold 850 W 80+ Gold Certified Semi-modular ATX Power Supply  ($129.99 @ Newegg)
Total: $1931.05
Generated by PCPartPicker 2021-02-11 02:58 EST-0500
Looking to downgrade only to fit within budget. Trying to upgrade my budget at the same time though.
