USB mic low-pitched noise.
kecstama
Hi!
I just bought a new USB mic. It's a Superlux E205U MK2.
First I tried it with my laptop, 0 noise, great sound ect. ect, but when I plug it into my desktop it has a loud low pitched noise which gets louder when I'm using my mouse.
It's not my mouse's fault, because when I completely unplug every peripheral, it still has the humm, but a bit quieter.
I'm not sure what to do. Is it a groundloop? If yes, how can I eliminate that?
I've tried different USB plugs, front/back even my monitor's USB outs.
Update: The noise "changes" when running FurMark.
It's not louder, it's like I can hear the thing ramp  and down.
Probably a noisey psu, I've had "coil whine" come through my audio before.  In my case it was a replacement psu (still top notch) and the noise went away after a few month's.  It was directly tied to my gpu activity but typically it's a high pitched noise.
If you want an immediate solution I would try some way of getting distance from your onboard audio, maybe something like a usb sound card would work (*maybe).  I'm honestly not smart enough to know what it is but my assumption is it's electrical noise going back through the psu.  For me it was my USB connection and it was removed when I went with a galvanic solution IE: no physical connection to my computer.  After a few month's I went back to a physical usb connection and the noise was gone.  I later replaced the psu with my rma psu and it made no noise even being brand new.
Here is a video of Josh Valour having issues with a noisey PC though he is more or less asking for advice than giving a solution.
Open-Back - Sennheiser 6xx - Focal Elex - Phillips Fidelio X3 - Harmonicdyne Zeus -  Beyerdynamic DT1990 - *HiFi-man HE400i (2017) - *Phillips shp9500 - *SoundMAGIC HP200
Semi-Open - Beyerdynamic DT880-600 - Fostex T50RP - *AKG K240 studio
Closed-Back - Rode NTH-100 - Meze 99 Neo - AKG K361-BT - Blue Microphones Lola - *Beyerdynamic DT770-80 - *Meze 99 Noir - *Blon BL-B60 *Hifiman R7dx
On-Ear - Koss KPH30iCL Grado - Koss KPH30iCL Yaxi - Koss KPH40 Yaxi
IEM - Tin HiFi T2 - MoonDrop Quarks - Tangzu Wan'er S.G - Moondrop Chu - QKZ x HBB - 7HZ Salnotes Zero
Headset Turtle Beach Stealth 700 V2 + xbox adapter - *Sennheiser Game One - *Razer Kraken Pro V2
DAC S.M.S.L SU-9
Class-D dac/amp Topping DX7 - Schiit Fulla E - Fosi Q4 - *Sybasonic SD-DAC63116
Class-D amp Topping A70
Class-A amp Emotiva A-100 - Xduoo MT-602 (hybrid tube)
Pure Tube amp Darkvoice 336SE - Little dot MKII - Nobsound Little Bear P7
Audio Interface Rode AI-1
Portable Amp Xduoo XP2-pro - *Truthear SHIO - *Fiio BTR3K BTR3Kpro
Mic Rode NT1 - *Antlion Mod Mic - *Neego Boom Mic - *Vmoda Boom Mic
Pads ZMF - Dekoni - Brainwavz - Shure - Yaxi - Grado - Wicked Cushions
Cables Hart Audio Cables - Periapt Audio Cables
Speakers Kef Q950 - Micca RB42 - Jamo S803 - Crown XLi1500 (power amp class A)
*given as gift or out of commission
I have an external soundcard, but that's not noisy at all. It's just the USB mic.
My PSU is kinda on the budget side, It's a Zalman GS500? idk, something like that.
I made a cable which has separate Data and Power In-s. Data side into the PC, Power side into a powerbank and the noise is 90% gone. It's finally usable.
Not the perfect solution, but it's working.
Nice man, good to know that was the problem.  Also expensive psu's can still do it.  In a few month's I'd try going all connected to the pc and see if it's gone and at me with the result's because I'm curious to know.
DAC S.M.S.L SU-9
