i have both low cpu and gpu usage which are causing low fps in all games they hover around 40-50% both ,  my 1080ti cant get more then 80fps on Cod mw multiplayer on low settings  , when i turn the settings up and scale up the graphics i get from 90% - 98% gpu usage but still on a low frame rate , i tried playing on A different monitor resolution i have both a 2k res monitor and a 1080p full hd monitor both had similar fps and usage i tried everything new drivers,  updating bios,  chipset drivers , setting all settings to high preformance on windows and nvidia  control panel bus interface is  ( PCle x16 3.0 @ x16 3.0 ) nothing seems to work please if any body can help id really appreciate it its driving me crazy i want them high frame rates
pc specs ( pc was made for editing and work ) :
AmdThreadripper 1950x CPU
GTX 1080TI GPU
32 GB of Ram
Asus zenith extreme Motherboard
https://linustechtips.com/topic/1304502-both-low-cpu-and-gpu-usage/
You're just CPU limited. First gen TR cores are slow, that CPU only gives high performance on software that can use many of them efficiently which isn't the case of most games.
F@H
GPD Win 2
The reason you're getting low GPU utilization is because your CPU is quite slow when it comes to gaming because it has quite bad single threaded performance.
The reason you're getting low CPU utilization as well is because your CPU has 16 cores and 32 threads, and only a portion of those can be fully utilized while gaming.
The more I learn, the more I realise I don't actually know anything.
Recommendations: Lian Li 205m (sleek, pretty decent airflow for a non-mesh front panel and cheap), i5-10400f (Ryzen 5 3600 performance, 20% cheaper), Arctic P14 PWM fans, Logitech g305.
