Linux extremely high fan speed.
Solved by jj9987,
The wiki is for Arch Linux, but it applies mostly for other distros as well.
https://wiki.archlinux.org/index.php/fan_speed_control
EDIT: Depending on the system, the support for managing all the fans might not be possible. Just try it out. If that doesn't work, then unless you find some other solution for your specific system/platform, you don't have a lot of options.
