I wanted to replace my old synology Nas with a decent server for my movies and some game servers for both of my sons. I decided to put everything in one Maschine. So I bought a used mobo/CPU/RAM combo of eBay.
I bought a supermicro x9drl-if
2x Intel Xeon e5 2670v1
and 4 x 8gb 2rx8 12800e in a set.
the vendor insured me that everything worked so I bought it.
Now the to problem.
System won’t boot.
No video Signal - can’t see proper post code only Buzzer code.
Sound is in slowmo
No pci card attached. only via onboard vga  connected to Monitor
Onboard video is enabled via pin bridge
I Tried to boot with 2 cpus 4 sticks, 2 cpus, 2 sticks, swapped them, and cleared cmos multiple times.
Booted with only 1 cpu and 2 sticks and Switches cpus and ram
Checked if the ram is in the correct slot everytime
I can’t check if mb, cpu, ram is broken because I only have what I bought.
The fans are spinning mobo led is blinken
PDF is the mobo manual
Im not a professionell.
Does anyone have any ideas?
Greeting from Germany
MNL-1298.pdf
https://linustechtips.com/topic/1304043-system-won%E2%80%99t-boot-buzzer-code/
Are you sure it came with PC3-12800E memory?
I'm pretty sure the Xeon E5 series doesn't support unbuffered memory.
You need to buy DDR3 RDIMMS instead, which are registered.
E memory is ECC UDIMM, which is for entry level servers and workstations.
Usually equipped with a Xeon E(3) or Core i3/Pentium/Celeron.
Edit:
The manual does mention UDIMM support, but it doesn't list 8GB DIMMs as supported on UDIMM. Might indeed be incompatibility.
PC Specs - AMD Ryzen 7 5800X3D MSI B550M Mortar - 32GB Corsair Vengeance RGB DDR4-3600 @ CL16 - ASRock RX7800XT 660p 1TBGB & Crucial P5 1TB Fractal Define Mini C CM V750v2 - Windows 11 Pro
Here’s the ram I have.
the seller claimed that pc worked fine till the end.
Im completely new to the ecc ram stuff.
i thought when I buy everything together I can skip the troubleshooting stuff right now but that didn’t work well i guess
thank you for the fast reply
