GPU is needed. According to the information presented, you would need around a 400 watt PSU. If you're using some other GPU, you may need a more powerful PSU.
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139456
If you are running a GPU like a 7950 or a GTX 660ti a 650W psu will be adequate. I would recommend the SeaSonic X Series X650 Gold psu.
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139675
If you're going to add 1 gpu, You'd be good with 500w. 2 low end gpus, 750. 2 high end gpus, 850. 3 or more, 900-1k. All at a decent minimum of 80 plus Bronze
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139689
if you have something that will be fine with a 650 watt buy the X650...RIGHT NOW...it's on sale for $94.99 + a $15 rebate...total cost of $79.99 for 80+ gold psu with modular ribbon cables.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139781
Actually, 750 should be good for even 2 680s.
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139798
gtx 680 only uses 228 watts max (during furmark) so a 650 watt could pull it off as well
https://linustechtips.com/topic/13040-psu-for-system/#findComment-139847
