[SOLVED] Interent not working - exam in 1 hour!!!!!!!
gal-m
I get this message on most websites, such as wikipedia, reddit, etc. DNS_PROBE_FINISHED_NXDOMAIN
My Microsoft Teams also says it can't get online - this is where I'm taking my exam.
I can still google normally and LTT forums load normally. I restarted my Router and PC.
I know I should have posted this under troubleshooting but I NEED this to get seen as as many people as possible - I am sincerely sorry.
Sorry I just saw that you said you restarted the PC, but it looks like it might be a DNS issue, do you have any VPNs on?
4 minutes ago, ubtrpn said:
Have you tried restarting your computer?
Restarted every bit of tech in the house. Computer, router, modem, switch. Everything.
That is a DNS error. Try setting your DNS to Google's (8.8.8.8 and 8.8.4.4) or Cloudflare's (1.1.1.1 and 1.0.0.1).
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
@jj9987 & @lexusgamer05 just got word from the IPS. They have a malfunction on their side and are trying to resolve it ASAP... not sure I'll be able to make it to my exam 😞
It actually isn't. Its an SSL Certificate error.
Main Rig:-
Server:-
I agree with jj9987 It looks like your ISP dns is having trouble but you can bypass that by swapping your dns servers for googles. Good luck!
DNS_PROBE_FINISHED_NXDOMAIN indicates DNS failed to resolve domain to IP address, NXDOMAIN is the response when the requested domain cannot be resolved.
Ahh my apologies, I was confusing it with a similar sound error in Firefox that triggers when an SSL cert doesn't cover a subdomain (RX_MESSAGE_TOO_LONG).
Main Rig:-
Server:-
