MSI GD65 help pls
Go to solution Solved by bradscoolio,
Here is the MSI z77a gd65 LAN driver: http://www.msi.com/service/download/driver-17639.html
Hi everyone. I was wondering if someone could help me out with my mobo not detecting internet.
I bought this mobo used and it didnt come with a CD. My build does not have optical drive anyways.
When i plug in an ethernet from router and from modem my moo wont detect internet. when i click trouble shoot it says "windows did not detect a proper network adabtor."
Baby Beast:
B450m Mortar // 3700x // T Force Vulcan 16gb // Gaming X Trio RTX 2070S // sx8200 pro // 850W G
https://linustechtips.com/topic/13038-msi-gd65-help-pls/
Ive been at ther website for like 5 min theres so many i dont know which one it is. i tried the genie but it didnt work says "error not support this software". Exact quote using windows 7 ultimate 64
icon_download.pngNetwork Genie Description Hardware:
MSI mainboard with Realtek LAN chip (8111E or newer).
Software specifications:
Realtek LAN driver Version 1.00.0000 Type Utility Release Date 2012-12-12 OS Win8 32, Win8 64, Win7 64, Win7 32, Vista 64, Vista 32 Download NetworkGeni_mb.zip File Size 5.62 MB Note N/A
Baby Beast:
https://linustechtips.com/topic/13038-msi-gd65-help-pls/#findComment-139457
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/13038-msi-gd65-help-pls/#findComment-139510
Thank you, thank you, thank you, thank you, thank you Would you happen to know why is doanloading so slow. its going at 166KB and when i do a speed test i get 1800+
Baby Beast:
https://linustechtips.com/topic/13038-msi-gd65-help-pls/#findComment-139554
No problem :)
Unfortunately the msi download servers for their drivers are just like that, i had the same problem when downloading the entire suite of drivers from them and it took me well over 24 hours to download :/ sorry, just gonna have to wait it out.
PS: remember to mark the thread as solved once you've found the solution :)
https://linustechtips.com/topic/13038-msi-gd65-help-pls/#findComment-139595
