nice
Work Rigs - 2015 15" MBP | 2019 15" MBP | 2021 16" M1 Max MBP | Lenovo ThinkPad T490 |
AMD Ryzen 9 5900X  |  MSI B550 Gaming Plus  |  64GB G.SKILL 3200 CL16 4x8GB |  AMD Reference RX 6800  |  WD Black SN750 1TB NVMe  |  Corsair RM750  |  Corsair H115i RGB Pro XT  |  Corsair 4000D  |  Dell S2721DGF  |
Fun Rig - AMD Ryzen 5 5600X  |  MSI B550 Tomahawk  |  32GB G.SKILL 3600 CL16 4x8GB |  AMD Reference 6800XT  | Creative Sound Blaster Z  |  WD Black SN850 500GB NVMe  |  WD Black SN750 2TB NVMe  |  WD Blue 1TB SATA SSD  |  Corsair RM850x  |  Corsair H100i RGB Pro XT  |  Corsair 4000D  |  LG 27GP850  |
https://linustechtips.com/topic/1303749-some-cable-management/#findComment-14466739
1 minute ago, ragnarok0273 said:
Is this your main system?
It's a backup for a Win 98 PC that I  use everyday that supports some legacy photographic equipment that will not run in a VM. So I need to have  working Win98/NT4 hardware ready to run. It's fun to tinker with as well.
https://linustechtips.com/topic/1303749-some-cable-management/#findComment-14466766
What hardware do you have in it?
I have a similar build, but it's out of commission right now due to a dead hard drive and graphics card.
Specs:
Pentium III 500 Slot 1
Asus P3V 4X
2x1GB SDR PC133 RAM
Deer Computer 250w
NEC CDR-500 SCSI optical drive
SCSI card
I have some parts coming, though:
80GB HDD
15GB HDD
ATI Radeon 9250
I'm going to put Windows 2000 on it because otherwise I can't use my 1GB sticks.
As it is, I can only use 2 of my 4.
PLEASE STOP [Killing] ME I WILL GIVE Y OU ANOTHER DEAL.
https://linustechtips.com/topic/1303749-some-cable-management/#findComment-14466772
The main Win98 PC is:
ASUS P4P-EX
Intel P4 3.0GHz
1GB PQI DDR 400 RAM
84GB IDE SSD with adapter (I'm so over spinning hard drives)
NEC CD ROM
Internal NEC Zip drive
Adaptec 2906 SCSI card for legacy photographic equipment
Radeon 9200 SE
Additional parallel card for second legacy printer
Apart from the specialised legacy photographic software I require, this machine runs Office 2000, Photoshop 7.0 and other productivity/workstation apps very reliably. I even allow it on my local network where it has some limited sharing abilities.
It is disturbingly satisfying when you get all the chipset drivers for old motherboards to install instead of the basic default Windows drivers.
When the ISA and PCI slots are all loaded up with cards and the Device manager doesn't show any yellow flags, that means you can finally get some sleep.
https://linustechtips.com/topic/1303749-some-cable-management/#findComment-14466949
