I currently have an InWin 101 case with a MasterLiquid ML240L AIO from CoolerMaster. I need new fans but I dont know a lot about cooling and what fans I should get, and where fans should be placed for optimal airflow. My configuration as of right now is just my radiator on the two "front" spots, and I have both fans on it as exhaust. The case has a single rear fan, 3 bottom fans and the two "front" fans that I have my radiator and fans on. All are 120mm
https://linustechtips.com/topic/1303663-need-help-with-fan-configuration/
Which ones are intake and exhaust (if you can see the frame it is exhaust)?
Main System:
CPU
 - AMD Ryzen 5 3600 (OC)
Motherboard - Asus ROG Strix B450-F Gaming II
RAM - Crucial Ballistix 3200 Mhz 16 GB (8x2)
GPU - Asus Dual RTX2060 12GB
Case - Corsair 4000D Airflow
Storage - Crucial BX500 480 GB - Seagate BarraCuda 7200 RPM 2 TB
PSU - PowerSpec 650 Watt 80 Plus Bronze (looking for replacement, its loud)
Cooler - Hyper 212 Evo with two RGB fans
NAS:
CPU: AMD Athlon II X4 640 (had on hand)
Motherboard: HP Slimline S5610F Motherboard from Ebay
RAM: EVGA Superclocked 16gb
Storage: 2x 4TB WD Blue and old asf caviar se16 250gb because I had it and its worked for so long I don't trust anything else as much
GPU: Integrated on the mobo
Case: Old PowerSpec case from Micro Center (that can hold 8 hard drives)
PSU: EVGA W3 500W
Cooler: AMD stock cooler at PS4 RPM's that keeps the cpu at 14-24 degrees
34 minutes ago, narrdarr said:
depending on the space available from your hardware.
2x120mm exhaust on Aio (aka side front)
3x 120mm bottom  intake
1x 120mm rear intake.
as for fans
I'm guessing you want rgb? what motherboard do you have?
no rgb, i just want good quality fans that i dont gotta spend a shitload on. i have an ASRock B450M PRO4
2 hours ago, bundleo210 said:
alright man appreciate the help
I got hung up, but I was literally going to say the same fans because I have had good experiences with them.
Main System:
CPU
NAS:
PSU: EVGA W3 500W
