PS4 problem need help:)
Go to solution Solved by jaslion,
Just now, Xander10 said:
it is slow when i load games. Ive had it like a week ago
Oh that is normal also no need to clean it if it's new. They still use disks and slow hdds so yeah loading will take forever that is totally to be expected.
3 minutes ago, Xander10 said:
ive tried that and looked for youtube vids and its still slow
its common with PS4/PS4 Pro and Xbox Ones.. the drives are slow ass mechanical drives. Load times have always sucked. Only option to speed it up would be to replace the drive with an SSD.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14465749
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14465757
A ssd does very little to improve loadtimes sadly in the 8th gen consoles.
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14465758
how do i replace it?
Edited by Xander10
i forgot something
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14465763
how do i speed it up
you really cant. Its a hardware limitation. An SSD can help, but wont boost load times greatly like it does on a PC compared to Mechanical drives.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14465764
Look up PS4 Pro load times of an HDD vs SSD. If you think it's worthwhile, then go to PCPartpicker and sort SSD's by $/GB and get whatever 1tb or 2tb drive you fancy. The SSD does help, but it not huge, and it depends on the game. The standard/slim PS4 gets no real advantage because of the CPU limitation, but the PS4 Pro does get a noticeable.
https://linustechtips.com/topic/1303640-ps4-problem-need-help/#findComment-14476693
