What can you say about this build? or can you recommend a build that is almost the same price.
1. Budget and Location
Budget: in Us Dollar its kindaa 400$
2. AIM
Number 1: for gaming , as you can see its a budget build so i'm not expecting to run in Ultra.
Number 2: Internet Browsing.
3.Monitor
Running in 1080p
4. Peripherals
i have it all. no problem with this
So here is the build!
APU: AMD A10-5800K 3.8GHz Quad-Core Processor  ($109.98 @ OutletPC)
GPU: HD 6670 (this is not counted in the total amount.)
Motherboard: ASRock FM2A75M Pro4+ Micro ATX FM2+ Motherboard  ($67.55 @ Newegg)
Memory: Kingston 4GB (1 x 4GB) DDR3-1600 Memory  ($44.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($59.23 @ OutletPC)
Case: Corsair 200R ATX Mid Tower Case  ($44.00 @ Newegg)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($32.98 @ Newegg)
Total: $358.73
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-22 09:58 EDT-0400)
Equality doesn't mean Justice.
https://linustechtips.com/topic/130331-build-for-my-friend/
How's this look instead? http://pcpartpicker.com/p/3eBOR
https://linustechtips.com/topic/130331-build-for-my-friend/#findComment-1737786
