3 minutes ago, ClickMeFishy said:
My case has 4 front facing USB ports and there's 2 USB 3.0 cables but my mobo only has one usb 3.0 header. Is there any work around to get all 4 ports working?
You can get PCIe cards that provide an additional USB 3.0 header.
Image result for Orco usb 3.0 pcie card
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1303200-usb-30-cable-help/#findComment-14462586
This is the solution if it's important to you that all four ports actually run at USB 3.0 speed.
If not, you can get adapters like this and connect the other pair of ports to a USB2 motherboard header: https://www.amazon.com/Duttek-2-pack-Motherboard-Adapter-Converter/dp/B072ZV1566/
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1303200-usb-30-cable-help/#findComment-14462601
Thanks for the help
https://linustechtips.com/topic/1303200-usb-30-cable-help/#findComment-14462628
