After I built my PC I went into the windows download screen and started to try and download windows, I had a problem trying to download it because it "wasn't creating a new partition" that isn't the main problem, I just got a new problem recently where my PC wont go into the windows installer anymore after I boot it up with the USB in it.
What I've done to troubleshoot already:
-Unplugged USB and plugged it back in and then booted up again
-tried to change boot order(doesn't appear in boot order anymore)
-Done some searching on google and found nothing close to what my problem is
https://linustechtips.com/topic/1303181-pc-not-recognizing-widows-usb/
Something is wrong with the windows USB. Try a new installation.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
Do you have another PC or access to another PC? Have you tried USB with another machine to see if its the issue? Because this sounds like USB has become corrupted or something like that. I also don't understand what you mean with your initial problem or how its related here.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Guest
