His budget is €750 and this is what i came up with
PCPartPicker part list: http://de.pcpartpicker.com/p/3eg5h
Price breakdown by merchant: http://de.pcpartpicker.com/p/3eg5h/by_merchant/
Benchmarks: http://de.pcpartpicker.com/p/3eg5h/benchmarks/
CPU: AMD FX-8320 3.5GHz 8-Core Processor  (€127.90 @ Caseking)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (€33.40 @ Amazon Deutschland)
Motherboard: Gigabyte GA-970A-DS3P ATX AM3+ Motherboard  (€66.91 @ Amazon Deutschland)
Memory: Kingston Beast 8GB (2 x 4GB) DDR3-1600 Memory  (€72.51 @ Amazon Deutschland)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (€52.99 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 760 2GB Video Card  (€227.90 @ Amazon Deutschland)
Case: Fractal Design Define R4 (Titanium Grey) ATX Mid Tower Case  (€90.45 @ Amazon Deutschland)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  (€70.06 @ Hardwareversand)
Total: €742.12
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-22 11:51 CET+0100)
https://linustechtips.com/topic/130293-build-for-a-friend/
The build already looks great to me
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734664
He could probably save some money on the case choice and still get a decent one.  As for the motherboard while I like Gigabyte that one chosen doesn't rate very well (60/100 rating basically on the net all over) considering the reviews I am seeing for it. How about spend a bit more and get a 990X or 990FX motherboard from Gigabyte?  They rate much better.  Still though there are other motherboard options .... looking now at the links you gave and all and now realize I am too tired to look further but really if you could find a better motherboard then you are all set.
Too many ****ing games!  Back log 4 life! :S
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734669
Looks good to me, good job.
Case Bitfenix Ghost, Mobo Asus Maximus VIII Ranger, CPU i7 6700K @4.2 Ghz cooled by Arctic cooling Freezer i30, (barely). GPU Nvidia GTX 970 Gigabyte G1 @1519Mhz core, RAM 16Gb Crucial Ballistix CL16 @2400Mhz. SSD 128GB Sandisk Ultra Plus as my OS drive. HDD's  1TB  Seagate ST31000524AS its OEM, 3TB Seagate Barracuda, 2x 500GB WDC Blue (RAID 0)
If it isn't working absolutely perfectly, according to all your assumptions, it is broken.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734670
He could probably save some money on the case choice and still get a decent one. As for the motherboard while I like Gigabyte that one doesn't rate very well considering the reviews I am seeing for it.
so wich case should he get then?
PCPartPicker part list: http://de.pcpartpicker.com/p/3eggK
Price breakdown by merchant: http://de.pcpartpicker.com/p/3eggK/by_merchant/
Benchmarks: http://de.pcpartpicker.com/p/3eggK/benchmarks/
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+ Motherboard (€113.83 @ Amazon Deutschland)
Case: Corsair 330R ATX Mid Tower Case (€79.90 @ Caseking)
Total: €778.49
(Generated by PCPartPicker 2014-03-22 12:07 CET+0100)
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734683
There are cheap reference XFX 290s in Germany, if your friend could spend a bit more, I'd go with that.
SuperNova: CPU: Intel Core i5 4670k @4.6 GPU: Sapphire R290 Tri-x @1200, @1350, MOBO: MSI Z87 G45 Gaming, RAM: 16Gb HyperX Fury White @1866, PSU: CORSAIR TX750M, CASE: Arc Midi R2, SSD: Kingston 120gb SSD,
COOLING:
H100i w/ 2x Nb eLoop 800rpm
Check out my build log Black Dawn Check out my build log Supernova
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734707
Good job on switching the board.  He will definitely be happy. Why not play it safe eh and pay a little more to get a well rated board eh? Also with the board you changed to he gets SLI support and other features and again this rates an 80/100 across the net. 80/100 better than 60/100 (http://www.amazon.com/GIGABYTE-GA-990FXA-UD3-990FX-SATA-Motherboard/dp/B0055QYKQO) I spent $30 more or so on a 990FX board for my son when I did his last build cuz I like having the option of SLI if we went Nvidia later on and I liked that the board rated better and so far it has paid off as we ended up getting rid of his AMD card for an Nvidia card and also the motherboard has run flawlessly.
Any chance your friend is going to maybe want to overclock and run another card in there or run a much better card in there in the future?  For me personally while that is wonderful that it is a fully modular psu at a decent price the wattage is quite low. Better psu?
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734709
Or get a MSI 780 Lightning for around a €100 extra and is lookes WAY beter than a R9 290 (reference)
But he's on a tight budget isn't he?
COOLING:
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734741
@ -CODE-STEP-
Memory:  Avexir Core Series 8GB (2 x 4GB) DDR3-1600 Memory  (€59.90 @ Caseking)
Video Card:  Gainward GeForce GTX 770 2GB Video Card  (€295.95 @ Amazon Deutschland)
Case:  BitFenix Comrade ATX Mid Tower Case  (€39.02 @ Amazon Deutschland)
Total: €787.61
(Generated by PCPartPicker 2014-03-22 12:27 CET+0100)
Linus Sebastian said:
The stand is indeed made of metal but I wouldn't drive my car over a bridge made of it.
https://youtu.be/X5YXWqhL9ik?t=552
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734749
@-CODE-STEP-
PCPartPicker part list / Price breakdown by merchant / Benchmarks
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€47.55 @ Pixmania DE)
Total: €787.61
:lol: That's actually reaaaaally good.
well he could get €1100 (€350 extra) but get a way better gaming rig so...
You also need to consider if he needs peripherals.
COOLING:
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734753
CPU:  Intel Core i5-4440 3.1GHz Quad-Core Processor  (£125.99 @ Aria PC)
Motherboard:  MSI H87M-G43 Micro ATX LGA1150 Motherboard  (£59.82 @ Amazon UK)
Memory:  Patriot Signature 8GB (2 x 4GB) DDR3-1600 Memory  (£57.15 @ Ebuyer)
Storage:  Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£39.14 @ Aria PC)
Video Card:  Asus GeForce GTX 760 2GB Video Card  (£186.98 @ Dabs)
Case:  Fractal Design Arc Mini R2 MicroATX Mini Tower Case  (£64.98 @ Novatech)
Total: £580.04
(Generated by PCPartPicker 2014-03-22 11:15 GMT+0000)
All these recommendations are nice and this is a cheap one but please don't let your friend get an MSI motherboard.  Go with Asus or Gigabyte mid range boards and he will be guaranteed to be happy.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734763
I have a mid-high end msi board and it's just amazing...they are good.
COOLING:
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734771
@-CODE-STEP-
Total: €787.61
Nice job here kind of but questions about that ram ...
Anyone want to rate it?
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734775
MSI motherboards are as good if not better than gigabyte motherboards,I personally would not hesitate to recommend or buy one for myself in a build.
EDIT:@DeViLzzz have you heard of the MSI GD65 Gaming?It was recommended by most reviewers as one of the best all around motherboards.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734779
No way you are going to convince me that choosing MSI over Asus or Gigabyte is a smart move.  Also there is a reason MSI has to sell for less at times with their boards and it wouldn't be that they want to make less money than their competitors. The reason is they can't sell certain boards at certain prices like Asus and Gigabyte can cuz those companies are more trusted at this point with this type of product.
Nobody in their right mind goes looking for an MSI motherboard when shopping for motherboards.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734780
Avexir is the company that made MSI's mpower ram,so with that in mind I feel they're decently reputable.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734788
You also had no problem recommending some obscure ram.  Please explain that choice.
.. and I guess you just did ahead of this post.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734794
PCPartPicker part list: http://de.pcpartpicker.com/p/3egIK
Price breakdown by merchant: http://de.pcpartpicker.com/p/3egIK/by_merchant/
Benchmarks: http://de.pcpartpicker.com/p/3egIK/benchmarks/
Video Card: MSI GeForce GTX 770 2GB Video Card
Case: NZXT H440 (White/Black) ATX Mid Tower Case
Power Supply: Corsair RM 650W 80+ Gold Certified Fully-Modular ATX Power Supply
Price €888,31  (€913,72 with shipping)
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734806
I'd rather have Asus, Gigabyte and ASRock before even considering MSI.
You have some really skewed opinions.
ASRock is always thought of as one of the worse brands, most people think of it as only slightly better than Biostar.Personally I feel they're only slightly below msi and gigabyte,but still.
I can gaurentee you that MSI vs ASRock a large majority of people would pick MSI.
MSI vs Gigabyte it could go either way,but I see MSI winning a few more people over than Gigabyte.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734830
I'd rather have Asus, Gigabyte and ASRock before even considering MSI for a motherboard and I think quite a few people would agree with that.
AsRock?! Low end ASRock boards are rated as one of the worst ones! Only because MSI is not as famous as ASUS or Gigabyte, it doesn't mean their products aren't as good as the others. Just look at MSI's Lightning, Gaming, Hawk, Lighting series! I really don't get your point. It's like saying that PNY and PALIT aren't good manufacturers because they're not famous.
COOLING:
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734836
Did you know that Asus wanted to buy it back because they were making some really good boards? (Remember hearing this on WAN Show) Also it is much better than Biostar. Seriously please give me a break comparing ASRock to Biostar. LOL Are you now going to go and say ECS boards are better too?
Don't drag brands in that I did not mention and no I don't trust MSI to make a better board than Asus, Gigabyte or ASRock for good reason.
As for looking at MSI yes look at the company that did not listen to Nvidia and was ***** slapped for it. Sorry but not a company to be trusted.
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734837
Why change this much and add €100?
I mean if you went with my build ,which I see nothing wrong with,you could use that extra 100 for an R9 290.
Video Card:  Asus Radeon R9 290 4GB Video Card  (€441.12 @ Amazon Deutschland)
Total: €932.78
(Generated by PCPartPicker 2014-03-22 12:54 CET+0100)
https://linustechtips.com/topic/130293-build-for-a-friend/#findComment-1734855
