Need help understanding SMART ctl data
Go to solution Solved by Electronics Wizardy,
1 minute ago, G9XFTW said:
Here's the toshiba drive. Purchased Jan 2021 or something.
"Test #","Type","Status","% Completed","Lifetime hours","LBA of the first error"
1,"Short offline","Completed without error","100%","738","-"
"Description","Value","Flags","Page, Offset"
"General Statistics (rev 1)","","",""
"    Lifetime Power-On Resets","368","---","0x01, 0x008"
"    Power-on Hours","782","---","0x01, 0x010"
"    Logical Sectors Written","4,605,019,643","---","0x01, 0x018"
"    Number of Write Commands","10,674,199","---","0x01, 0x020"
"    Logical Sectors Read","2,090,263,953","---","0x01, 0x028"
"    Number of Read Commands","10,988,430","---","0x01, 0x030"
"Rotating Media Statistics (rev 1)","","",""
"    Spindle Motor Power-on Hours","778","---","0x03, 0x008"
"    Head Flying Hours","778","---","0x03, 0x010"
"    Head Load Events","396","---","0x03, 0x018"
"    Number of Reallocated Logical Sectors","0","---","0x03, 0x020"
"    Read Recovery Attempts","1","---","0x03, 0x028"
"    Number of Mechanical Start Failures","6","---","0x03, 0x030"
"General Errors Statistics (rev 1)","","",""
"    Number of Reported Uncorrectable Errors","1","---","0x04, 0x008"
"    Resets Between Cmd Acceptance and Completion","0","---","0x04, 0x010"
"Temperature Statistics (rev 1)","","",""
"    Current Temperature (C)","33","---","0x05, 0x008"
"    Average Short Term Temperature (C)","33","N--","0x05, 0x010"
"    Average Long Term Temperature (C)","32","N--","0x05, 0x018"
"    Highest Temperature (C)","38","---","0x05, 0x020"
"    Lowest Temperature (C)","25","---","0x05, 0x028"
"    Highest Average Short Term Temperature (C)","36","N--","0x05, 0x030"
"    Lowest Average Short Term Temperature (C)","25","N--","0x05, 0x038"
"    Highest Average Long Term Temperature (C)","35","N--","0x05, 0x040"
"    Lowest Average Long Term Temperature (C)","25","N--","0x05, 0x048"
"    Time in Over-Temperature (Minutes)","0","---","0x05, 0x050"
"    Specified Maximum Operating Temperature (C)","60","---","0x05, 0x058"
"    Time in Under-Temperature (C)","0","---","0x05, 0x060"
"    Specified Minimum Operating Temperature (C)","0","---","0x05, 0x068"
"Transport Statistics (rev 1)","","",""
"    Number of Hardware Resets","1,805","---","0x06, 0x008"
"    Number of ASR Events","658","---","0x06, 0x010"
"    Number of Interface CRC Errors","0","---","0x06, 0x018"
CRUCIAL MX500
1,"Short offline","Completed without error","100%","1,664","-"
"    Lifetime Power-On Resets","1,900","---","0x01, 0x008"
"    Power-on Hours","1,664","---","0x01, 0x010"
"    Logical Sectors Written","2,747,345,506","---","0x01, 0x018"
"    Number of Write Commands","164,755,827","---","0x01, 0x020"
"    Logical Sectors Read","1,116,314,838","---","0x01, 0x028"
"    Number of Read Commands","270,914,830","---","0x01, 0x030"
"    Date and Time TimeStamp","4,294,967,296","---","0x01, 0x038"
"    Number of Reported Uncorrectable Errors","0","---","0x04, 0x008"
"    Resets Between Cmd Acceptance and Completion","140","---","0x04, 0x010"
"    Average Short Term Temperature (C)","34","---","0x05, 0x010"
"    Average Long Term Temperature (C)","34","---","0x05, 0x018"
"    Highest Temperature (C)","53","---","0x05, 0x020"
"    Lowest Temperature (C)","0","---","0x05, 0x028"
"    Highest Average Short Term Temperature (C)","42","---","0x05, 0x030"
"    Lowest Average Short Term Temperature (C)","0","---","0x05, 0x038"
"    Highest Average Long Term Temperature (C)","41","---","0x05, 0x040"
"    Lowest Average Long Term Temperature (C)","0","---","0x05, 0x048"
"    Time in Over-Temperature (Minutes)","39","---","0x05, 0x050"
"    Specified Maximum Operating Temperature (C)","70","---","0x05, 0x058"
"    Number of Hardware Resets","7,308","---","0x06, 0x008"
"    Number of ASR Events","1,467","---","0x06, 0x010"
"Solid State Device Statistics (rev 1)","","",""
"    Percentage Used Endurance Indicator","5","---","0x07, 0x008"
Yea that hdd looks like it has some issues. Id try to get a ssd as the linux boot drive, but worth the try to rma it.
I face random crashes on my PC. So I decide to test the drives via GUI App "GsmartControl" on Linux. It returned some values and data which I'm not sure if I should consider and go for an RMA.
Redflag stats-
Toshiba HDWD120: "Description","Value","Flags","Page, Offset"
 Crucial MX 500: "Description","Value","Flags","Page, Offset"
Is the Toshiba drive (Linux install) especially busted or something? I largely face the least issues on it.
https://linustechtips.com/topic/1302768-need-help-understanding-smart-ctl-data/
11 minutes ago, Electronics Wizardy said:
Can you show all the data from the drives?
This is a bad sign, normally means the drive is about to die.
CRUCIAL MX500
CRUCIAL MX500
