Hi guys,
I've recently upgraded my build by buying mobo, CPU, GPU, and ram.
I had an Intel Core i5 4670 and now I have a Ryzen 7 3800xt.
This is my current build:
https://pcpartpicker.com/list/PWKqQD
I made this upgrade in December so some months have passed now.
I sometimes experience sudden random hard reboots that are independent of the workload.
They do not happen very often, like once every two weeks.
When this happens the windows event viewer lists an Kernel-Power critical event with ID 41.
Sometimes they happen while I'm on Discord and other times they happen after a 3 hours session on COD.
I can't manage to figure out what could be the cause...
My cooler with push/pull configuration manages to keep the CPU at about 68-69 degrees while gaming even after many hours (even while rendering a long AE project the temperatures don't change much).
I keep my power plug connected with a wattage meter but I've never had problems before.
So what could be the cause??
Thanks in advance
EDIT: I remembered I'm currently using the 1216 Beta Bios.
Could It be the cause?
https://linustechtips.com/topic/1302433-sudden-hard-reboots/
