CPU repair
Go to solution Solved by JamesTheFolf,
Some good old Linus from while he was at NCIX
I accidently and carelessly bent a pin on my old CPU that I am using to build a Home Theatre PC for my family. It is a Ryzen 5 3600X. I haven't found anyone near me that does this sort of repair, and I trust this community the most to help find someone who does. Thanks!!
https://linustechtips.com/topic/1302067-cpu-repair/
How bad is it? Is the pin just bent or is it actually broken? You should be able to just bend it back yourself.
Main System: Phobos
AMD Ryzen 7 2700 (8C/16T), ASRock B450 Steel Legend, 16GB G.SKILL Aegis DDR4 3000MHz, AMD Radeon RX 570 4GB (XFX), 960GB Crucial M500, 2TB Seagate BarraCuda, Windows 10 Pro for Workstations/macOS Catalina
Secondary System: York
Intel Core i7-2600 (4C/8T), ASUS P8Z68-V/GEN3, 16GB GEIL Enhance Corsa DDR3 1600MHz, Zotac GeForce GTX 550 Ti 1GB, 240GB ADATA Ultimate SU650, Windows 10 Pro for Workstations
Older File Server: Yet to be named
Intel Pentium 4 HT (1C/2T), Intel D865GBF, 3GB DDR 400MHz, ATI Radeon HD 4650 1GB (HIS), 80GB WD Caviar, 320GB Hitachi Deskstar, Windows XP Pro SP3, Windows Server 2003 R2
https://linustechtips.com/topic/1302067-cpu-repair/#findComment-14453449
