Different project settings for three monitors
Go to solution Solved by GorujoCY,
basically select screen 2 to duplicate and then select screen 3 to extend with the main screen or extend with display 2
i dont have a triple monitor to show very well how but yeah...
My dad needs some help. He has three monitors/screens available. On his main screen (laptop) and another screen, he would like to double them, so it would display the same thing on both of them. But on the third screen he would like it to be just separated and be on its own. Is there maybe an option to do that or not?
Make sure to quote me if you want me to respond
Turn your Mobile VR or PSVR Headset into a working 6DoF SteamVR one guide/tutorial (below):
My PC
Thank you for the fast response and also the solution that worked.
