Budget (including currency): $6500-$8000
Country: UK
Games, programs or workloads that it will be used for: ~Multi Users Using for Graphic Design
Well i was looking at this mother board not sure is it good ? ASUS WS C621E SAGE Other Motherboard for Intel LGA3647 CPUs
Only issue so far i see is that it does not have 2 m.2 slots on the mother board and i want to buy 2 of these https://www.corsair.com/uk/en/Categories/Products/Storage/M-2-SSDs/MP600-PRO-HYDRO-X-EDITION/p/CSSD-F2000GBMP600HXE#
4tb but for the second ssd how do i water cool it if i can t fit on the mother board?
my  technical Expertise are very low on this matter
Please Advise
https://linustechtips.com/topic/1301951-first-pc-bulid-any-help/
Country: UK
Please Advise
Water cooled ssd is one of the most diminished returns possible. Not worth it at all for the extra price.
If you're going to be making a mulit-user workstation out of this, I'd suggest using the 4 integrated U.2 ports that come on that motherboard, and configure them in a RAID 5 through the motherboard BIOS. Gives you blazing speed and redundancy, not to mention enterprise grade U.2 drives have far superior reliability than consumer grade M.2 drives.
Here is an example of an enterprise U.2 drive: https://www.kingston.com/unitedstates/us/ssd?sortby=nameatz&gclid=CjwKCAiAsOmABhAwEiwAEBR0ZsTBK46aVBkbHu4LmA4JYrgNx3ahBloQL6kY5aRYCAIXtYKUtMbOPhoC_gMQAvD_BwE&form factor=u.2&interface=nvme&use=servers and datacenters
I was wondering if this is possible. When I build my computer I wanted to have two hard drives the one from my current pc which has windows 10 and a m.2 nvme ssd both are 500gb but see if i could clone windows 10 from the 2.5 hhd to the m.2 ssd while they are both hooked up in my new built computer.
Well reading through  buying a PCI gen 4 ssd would not be compatible with the WS-C621E-SAGE please correct me if i am wrong so we'd have to stick to pci gen 3 right?
Further more i saw video by linus he used a 2666mhz ram and due that ram his mother board would not boot would it happen the same with the above
https://www.corsair.com/ww/en/Categories/Products/Memory/VENGEANCE-LPX/p/CMK192GX4M12P2666C16#tab-tech-specs
do i need to use a lower base then 2666 for it to be compatible
further more researching i believe this cpu will work fine with the lga-3647 socket
Intel Xeon Platinum 8180
But the block needed to cool it should it be square or narrow
EK Water Blocks EK-Annihilator Pro - Narrow ILM CPU water block Intel LGA 3647
OR
EK Water Blocks EK-Annihilator Pro - Square ILM CPU water block Intel LGA 3647
how do i know which one i need? i believe the EK blocks are the best for the LGA-3674
Please if someone can advise me
