Budget (including currency): 1,500
Country: Australia
Games, programs or workloads that it will be used for: Csgo, valorant, Fortnite, apex, cod
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): complete new build, Have all my peripherals need help with my cpu choice.
I’m planning on going 5600x but want a lower end cpu if possible with similar FPS in these games. Any recommendations would be appreciated
https://linustechtips.com/topic/1301428-what-cpu-should-i-use-please-help/
What are the rest of your specs?
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
Corsair 8x2 ddr4 3200mhz
Gigabyte b550 Aorus pro ax
Gigabyte 3060ti oc
Asus rog 650w psu fully modular
250gb nvme m.2 Samsung
011 dynamic xl
Corsair aio 360mm pro h150i
3x Corsair ll120 rgb fans
Gigabyte 3060ti oc
011 dynamic xl
r3 3100 should do you plenty fine. But if you plan on going on to harder and cpu intensive games you should get the 3600
Gigabyte 3060ti oc
011 dynamic xl
3300x or a 3600. Any which resolution and what refreshrate?
Desktop :
Laptop :
