Problem with ram
Go to solution Solved by WhitetailAni,
Because it's DDR(4) RAM, in hardware monitor programs it will read at half its speed.
If you multiply 1800 by 2, you get 3600.
There is no problem.
I have 2 sets of Corsair Vengeances RGB Pro 16GB 3600mhz ( total 4 sticks that adds up to 32 GB). I have A-XMP turned on in my bios and the bios says my sticks are running at 3600. When I check task manager and CPU-Z they both say my ram is running at 1800 mhz. I'm not really sure what is wrong and I would appreciate some help on this.
My specs :
Ryzen 3900x
MSI X570 GAMING PLUS
32 GB 3600mhz DDR4 RAM
MSI VENTUS RTX 3070
https://linustechtips.com/topic/1301212-problem-with-ram/
Welcome to the forums!!!
DDR means Double Data Rate, so as @ragnarok0273 said, multiply 1800 by 2 to get 3600.
Just to show you on my system, its the same and is working as intended.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
https://linustechtips.com/topic/1301212-problem-with-ram/#findComment-14446641
