I am getting these weird white/grey lines or fringes all over the place but as I move my cursor across it seems to temporarily disappear . I am using an external display but it's the same with the main screen .
This only happens with specific apps , so far I have found it on Microsoft teams and epic games ui.
I am using
MSI Gl65 ( i5 variant)
Graphics card : 1650
I5 9300H
https://linustechtips.com/topic/1300981-help/
I am facing weird display issues . There these white/grey lines which appear on the screen mostly concentrated on logos or symbols but it's all over the place and I cannot seem to find an issue , the issue persists even I use a external screen . I find this issue both on my main screen and external screen.
However the issue seems to be appearing on specific apps i.e. microsoft teams and epic games.
I am using msi Gl65 laptop ( i5 variant)
Gtx 1650
https://linustechtips.com/topic/1300981-help/#findComment-14444790
Gtx 1650
If its only in some apps that sounds like a driver issue. Install the newest from nvidia.
https://linustechtips.com/topic/1300981-help/#findComment-14444804
I am using
I5 9300H
its a driver issue or a you are using a bad cable! (my guess is it a driver issue) - download the latest driver from nvidia or use GeForce experience to download the drivers
hey! i know to use a computer
https://linustechtips.com/topic/1300981-help/#findComment-14444842
