So my sister just gave me her OnePlus 3. She gave it to me because she accidentally pressed the "Lost Device" option and now the phone is wiped and google locked. She cannot for the life of her remember the password to the account. And this basically renders the phone useless. All I want is for the phone to work again. And I have a question: Will installing a custom rom remove the lock? Like LineageOS?
Any help is appreciated. Also, I'm a bit of a dummy when it comes to custom recoveries and ROMs, so please can someone also help me with that
And before any of you say it:  I am 100% responsible for any device damages that may occur during the process and/or making the phone bricked
Make sure to quote me @Meowster  so that I see your reply
I love my job, being a sysadmin. It's very fun
https://linustechtips.com/topic/1300868-oneplus-3-need-some-help/
Try this and see if it helps.
Turn on the phone
Select the emergency call button
Dial the code *#812# and agree to the terms and conditions
This should move you to the main screen. From there do a factory reset. That should wipe the google account and get rid of the block.
Edit:
If that doesn't work then you can always go into recovery mode and wipe the phone from in there. But you shouldn't need to install a custom rom to bypass a google block. The phone just needs wiped.
Turn on the phone
Edit:
Thanks for that, I will try and let you know if it worked
Turn on the phone
Edit:
This works, at least on the OnePlus 5T. It's how i saved a 5T that was going to get thrown due to the previous owner forgetting the Google password.
"Many computer users often find themselves the victim of 105mm armor piercing discarding sabot fin stabilized rounds shot at their computer"
*although i try my best, don't expect me to be right 100% of the time.
Turn on the phone
Edit:
Well well, it didnt work sadly. Any other ideas maybe?
