Connect long RGB cables to Gigabyte Aorus mobo RGB header
Antony007
I am planning to light up my entire room with RGB led. I want to control those LEDs using the Fusion software that comes with Gigabyte so that my room's RGB keeps in sync with my PC RGB components (RAM, mobo, fans etc.). I am aware of power limitations.
So is there any way I can power the extended LEDs using an external power connector and at the same time controlling the LEDs using the Fusion software? Are there any kind of LED extender in the market? Can't find one in google, probably searching with wrong terms.
