Premier Pro help!
Solved by Electronics Wizardy,
1 minute ago, LittleCham said:Yes, how would I do that?
Basically check image sequence and select the first photo.
Link https://www.wikihow.com/Import-an-Image-Sequence-in-Premiere
Playgb2 ·
Posted in Troubleshooting1 -
1
1
5
kasdashd ·
4
6
Ishikudeska ·
Posted in New Builds and Planning2
play_circle_filled
Latest From ShortCircuit:
