Need help picking a Power supply
Go to solution Solved by Ankerson,
Yes you do need a 650W PSU.
The Corsair TX650M out of that list.
I'm building a pc for video editing and gaming and I need help with picking a power supply for it. I'm not from US so most of the PSU units from the PSU tier list is not available over here. Their prices vary a lot too and most of what's sold here is either out of stock or ridiculous priced.
This is my build:
Ryzen 7 3700x (Stock Cooler)
Gigabyte B550 Aorus Elite V2
Corsair Vengeance DDR4 16GB (LPX)
Gigabyte GTX 960 4G G1 (It's from my old rig, planning to upgrade to a 3070 / 3060ti)
NZXT H510 (with stock fans)
Kingston A400 240GB (Boot drive)
Seagate BarraCuda 3.5 inch 2TB
My options (converted to $$):
  • Corsair TX650M - $101
  • Silverstone ST65f-GS - $106
  • Silverstone VIVA650 Gold - $90
  • Silverstone ET650-G - $88
  • Silverstone ET505f - $78
  • Silverstone ET550-G - $72
  1. Do I really need 650W? (After the upgrade?)
  2. I pay my electricity bills so efficiency matters a lot too.
  3. Any other suggestions are welcome, I will try to see if they are available over here.
Life is a DIY project.
https://linustechtips.com/topic/1297902-need-help-picking-a-power-supply/
i9 9900K @ 5.0 GHz, NH D15, 32 GB DDR4 3200 GSKILL Trident Z RGB, AORUS Z390 MASTER, EVGA RTX 3080 FTW3 Ultra, Samsung 970 EVO Plus 500GB, Samsung 860 EVO 1TB, Samsung 860 EVO 500GB, ASUS ROG Swift PG279Q 27", Steel Series APEX PRO, Logitech Gaming Pro Mouse, CM Master Case 5, Corsair AXI 1600W Titanium.
i7 8086K, AORUS Z370 Gaming 5, 16GB GSKILL RJV DDR4 3200, EVGA 2080TI FTW3 Ultra, Samsung 970 EVO 250GB, (2)SAMSUNG 860 EVO 500 GB, Acer Predator XB1 XB271HU, Corsair HXI 850W.
i7 8700K, AORUS Z370 Ultra Gaming, 16GB DDR4 3000, EVGA 1080Ti FTW3 Ultra, Samsung 960 EVO 250GB, Corsair HX 850W.
I don't recommend Vengeance LPX RAM's, they are using really bad chips in that RAM. It sometimes doesn't work when the X.M.P is on, get Crucial Ballistix instead. It is a really good RAM.
For PSU, I recommend XPG Core Reactor. It is a really good PSU. Epic ripple values and good voltage regulation.
Anecdotal. I have really good 3000mhz CL15 LPX's. I actually got them to be stable at 3400mhz with timings of 16-20-20-38 (16-18-18-36 was unstable). With RAM, any of them could be good or bad, it's really a luck of the draw.
1. They aren't from the US so availability could be an issue. They even say "...most of the PSU units from the PSU tier list is not available over here"
2. it's most likely out of their budget and way overpriced for what it is.
3. It's more likely for them to be able to get a Seasonic Focus since that is what the Core Reactor is, just rebranded and maybe a different fan profile.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
I agree, I've a pair of CL16 3200mhz 8x2 sticks and they didn't have trouble running at the XMP profile it came with on my old Intel rig.
I couldn't find the XPG Core Reactor, but I found these:
  • Seasonic Core GM-650 - $83
  • Seasonic Focus Plus 550 SSR-550FX - price not listed.
Should I go with the Corsair TX650m (which was available in almost all the shops that I checked) or look for one of these?
I'd stick with the TXM, but that Core GM isn't so bad itself at that price. Personally would stick with the TXM since I like Corsairs customer service/RMA and never truly dealt with Seasonic service/RMAs.
MAIN PC:
TXM it is, it has a longer warranty period too. Thanks for your help!
