Lian Li configuration help
Go to solution Solved by Kleo Yan,
To answer your question. Yes, this is how you should be connecting it
For Galahad connect the Pump header directly to your motherboard fan header (run at full speed so you dont spoil your pump) then the argb, connect to the cable Q (refer manual) and connect it to the uni fan controller (Output 1 to 4, your choice)
For Strimmer plus, connect it to it's controller. at the other end, you will need a 5V 3pin to sm3p converter. you can get it here https://www.ebay.co.uk/itm/PC-motherboard-5V-3PIN-TO-AURA-RGB-FAN-SM3P-Socket-Multi-connectors-cable-ASUS/264896189467?hash=item3dad0b141b:g:I6MAAOSw8-5ey3U8 or here https://www.aliexpress.com/item/1005001598378033.html (choose 1 to 1 Female 5V 3pin) then connect it to your uni fan controller (Output 1 to 4, your choice)
just make sure to set your Strimmer controller to motherboard mode.
I have a series of the uni fan you might be interested.
Dos and Dont's (Part II) - https://youtu.be/QQHJUQvKwlY
Connection & The Controller (Part III) - https://youtu.be/Rm2emeyMUAk
o use Galahad AIO on Uni Fan Controller - https://youtu.be/XNCAeAX0mZQ
ome Break Fix! - https://youtu.be/8l4i5UjO3es
ow to link Push and Pull configuration fans - https://youtu.be/TIO8JxVZTi8
Using EK Vardar Evo 120ER aRGB Fans on this uni - https://youtu.be/bMRz2KVqbjA
SL120 Case Airflow Test - https://youtu.be/Qp3pYqOOjm4
SL120 Static Pressure Airflow Test - https://youtu.be/apDZ4v_jQBs
hope I wont get booted by moderator as some contain information that other reviewers have not covered.
In my newest build I decided to go with the Lian Li O11 Dynamic with the Galahad 360 AIO Uni fans and the strimmer pro cables for all the rainbow puke I could get my hands on. Everything is ordered and on its way my biggest question is it seems like I'll have some controller overlap with strimmer cables and the Uni fans. I know there is another controller with the Galahad but as I'm not using the fans included I don't think it will matter. My question is if the Strimmer plus cables can connect to the hub on the uni fans or if id have to use the controller for the cables and link it to the motherboard ARGB header giving me two controllers over my desired 1 controller preferred setup.
https://linustechtips.com/topic/1297349-lian-li-configuration-help/
