Heat and Space Concerns for my First PC Build.
Solved by WhitetailAni,
1 minute ago, Moderator41 said:How do I know if it is shorting or going to? I don't believe they are touching but like I said there isn't even enough room to fit a piece of paper between them. It was very very hard to put this pc together and get everything plugged in. my main concern is the clips for the Noctua fan I don't know if they are touching or not. I can only assume they are but I'm unsure if I could even get it off to put electrical tape on it. Thanks for the help.
Well, if something was shorting, your GPU would have let out the magic smoke.
You might want to put electrical tape over the open holes in the backplate though.
