I know HDMI cable quality means nothing since its digital but I though I might've heard Linus mention that at long distances the signal degrades. If this is true, how much will a 100ft HDMI cable change the signal? If not, what could cause signal degradation? Kinks? tears?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/129666-hdmi-cable-length/
basically the signal gets weaker the further down the cable you go, i believe its down to the conductivity of the wiring inside the cable
even the cheapst cable should reach up to 50ft easily, more expensive wiring is needed for longer distances
if its going really far, like say 300ft then a repeater is needed
a cheaper alternative is HDMI over ethernet
https://linustechtips.com/topic/129666-hdmi-cable-length/#findComment-1726143
