11 minutes ago, eddiemcgarrigle said:
Is your case supposed to have top fans?  If so there should be screw holes to enable fitment.  If not, and you do have room for some fans, you might want to arm yourself with a drill.
https://www.fractal-design.com/products/cases/focus/focus-g/black/
Here are the screw holes
https://linustechtips.com/topic/1296137-upper-case-fans/#findComment-14408535
