I have a sharkoon 500w bronze rated semi modular psu that i am missing one pci-e cable for. i found one in a drawer that looks the same but i do not know if it fits. The cables do not have much markiongs on it just small writing that says cst Я 03 in one end and cst Я 15 in the other end.
How do i know if it works with my psu?
https://linustechtips.com/topic/1295867-modular-psu-cables/
I hope you're not using that PSU for any high end components.
Use a multimeter to make sure the correct voltages are delivered to the correct pins on the other end of the cable.
https://linustechtips.com/topic/1295867-modular-psu-cables/#findComment-14406663
