I have never spent any more than $70 on a headset and I'm looking to upgrade to something better. I have been looking at the Astro a50's and a40's because i have a coupon for them, does anyone know if those are any good and if not can I have some recommendations my budget is anything under $300.
https://linustechtips.com/topic/129535-first-high-quality-headset/
Most of us here would recommend you buy a quality headphone and a mic separately.
Buy something that actually has high quality audio and the get something like a modmic for a mic.
www.modmic.com
Like watching Anime? Consider joining the unofficial LTT Anime Club Heaven Society~ ^.^
beyerdynamic and senhiser both make great headphones. Some of them will need a dac/amp or at least an amp. Go for the O2+ODAC or FiiO E10.
I will say straight away that a wireless "gaymin" headset is not the way to go. If you have that much cash to spend I recommend that you get good parts individually, the Headphones, Amp/Amp&DAC combo, and mic seperately. My recommendation for the money would be  a Fiio E10, DT 990's/HD 558/ATH AD-700X, and a Blue Snowflake or Modmic. Probably would be a better experience all around.
If you have a good coupon for the A40 and 50, I say why not get them. You definitely won't get the greatest quality compared to other headphone + microphone combos you can get, but you may be getting it cheaper. If you want to go for an external mic, try some DT 990s or HD558s with a Blue Yeti or something. Is there a certain type of sound you like? (more bass, mids, or treble)
My compooter: http://imgur.com/a/mDFsx?
i love my G930s, look for wireless, i didnt know freedom untill i got a wireless headset
also surround sound helps A LOT especially with bf and arma
bought mine on ebay, can get them for under 100 there
Current: CPU: Intel i7-8700k. Mobo: Gigabyte - Z370 AORUS Gaming 5. RAM: 16gb G Skill Trident Z RGB. GPU: EVGA RTX 2070 Super.
First: CPU: AMD FX-8350 @4.5GHz. Mobo: Asus ROG crosshair V formula-Z. RAM: 8GB Patriot Viper XTreme. GPU: Asus Radeon 7950.
If i were to get the AD 700X's with a mic right now i wouldnt be able to get Amp + Dac. would it be better to get the headphones first and would they still sound usable with basic on board equipment?
SInce the AD 700x's don't have a high impedence they can be powered easily by your onboard, I'd recommend it over the A40/A50 anyday of the week.
Like Mr Assassin said, you shouldn't need a DAC or amp. Also just wanted to point out that I have a 700X listed in the classified section. :)
