CPU instantly overheating
Solved by CombatAssassin,
22 minutes ago, Tristerin said:I cant say yes - but I will say 10k RPM would likely cause the entire unit to vibrate beyond such a spec that the fins would fly off. Who knows - either that or its reporting wrong because of similar issue.
Lay the case on its side (motherboard tray/cable management panel down) so that the tubes are sticking up, and rock it back and forth. Have to manually get those bubbles out (IF that is the issue - this is common especially after transporting a PC with an AIO imho)
Omg. It actually f’ing worked thank you so much. I got kinda worried there for a while. Now my CPU is idling at around 25-35*C and the pump is spinning at 2,2k RPM.
