Overclocking issues
Go to solution Solved by r1cky-,
I’ve solved it. My BIOS settings were screwed up, and I ran other preset. Now they’re good.
8 hours ago, r1cky- said:
What do you mean by showing anything?
When you are running a stress test in AIDA64, do any of the HWiNFO reasons for throttling show Yes in the Current column? You need to find out why your CPU is not running at full speed. If HWiNFO does not show any reasons for throttling then you have to look in your BIOS. Something has changed. When a CPU slows down 300 MHz, there is always a reason why this happened.
https://linustechtips.com/topic/1294789-overclocking-issues/#findComment-14400737
59 minutes ago, unclewebb said:
When you are running a stress test in AIDA64, do any of the HWiNFO reasons for throttling show Yes in the Current column? You need to find out why your CPU is not running at full speed. If HWiNFO does not show any reasons for throttling then you have to look in your BIOS. Something has changed. .
Where is this even... I can't find this setting at all... hw info is super confusing, which is why I use hw monitor but still curious..??
-Scott Manley, 2021
https://linustechtips.com/topic/1294789-overclocking-issues/#findComment-14400838
No throttling. Aida64 shows me 0% CPU Throttling and HWiNFO shows me the same thing.
https://linustechtips.com/topic/1294789-overclocking-issues/#findComment-14401303
1 hour ago, r1cky- said:
No throttling.
If nothing shows throttling, try running CPU-Z. Click on the Save Report (.TXT) button. Copy and paste that data to http://www.pastebin.com or attach that Report file to your next post. This will show how the various CPU registers are setup. Need to check if your BIOS is setting your CPU up correctly.
https://linustechtips.com/topic/1294789-overclocking-issues/#findComment-14401472
