deepcool Need some tips with Pump orientation
Solved by GhostRoadieBL,
both orientations are totally fine, Lines on the new build (blue) are not kinked and have a smooth curve so you're all good. AIOs have stiffer tubing than custom soft tubing so it takes a huge amount of force to kink the lines or mount them wrong.
It is still better to mount the pump/plate to the CPU before you mount the radiator so the mounting pressure is even and the lines aren't under tension potentially causing the plate to have uneven pressure or worst case lifted spots between the CPU and coldplate.
