Hi, yesterday I updated Windows. I came back and only monitor was light up but no video. So I turned it off and go. Now I'm trying to turn it on but my mobo says VGA error. I tired 2 gpus ( gtx 1650super and r7 370) and in both slots. My mobo is msi x570 gaming edge and cpu r5 3600. Please fast help because my lecturer is starting in half an hour.
Edited by tomcer2003
https://linustechtips.com/topic/1293678-vga-error-please-fast-help/
Uploaded? Update you mean?
reset the bios and try again.
5 minutes ago, tomcer2003 said:
Hi, yesterday I uploaded Windows. I came back and only monitor was light up but no video. So I turned it off and go. Now I'm trying to turn it on but my mobo says VGA error. I tired 2 gpus ( gtx 1650super and r7 370) and in both slots. My mobo is msi x570 gaming edge and cpu r5 3600. Please fast help because my lecturer is starting in half an hour.
usually you get a vga error if your card is not in all the way, since you tried two cards it could be a issue with your motherboard
Did you plug your display cable into the GPU? since the 3600 does not have an IGPU
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
Zoom with your phone for now, you won't solve this in 30minutes.
