New power supply
Go to solution Solved by Hudson Griffin,
Nvm I just had to manually short the power supply.
Nope, that's the same on all ATX connectors. That pin used to carry a -5v rail, but it's been removed since around 2003 because it's not necessary anymore. If you're having issues with the system, that blank pin isn't causing them.
Main PC:
AMD Ryzen 7 5800X • Noctua NH-D15 • MSI MAG B550 Tomahawk • 2x8GB G.skill Trident Z Neo 3600MHz CL16 • MSI VENTUS 3X GeForce RTX 3070 OC • Samsung 970 Evo 1TB • Samsung 860 Evo 1TB • Cosair iCUE 465X RGB • Corsair RMx 750W (White)
Peripherals/Other:
ASUS VG27AQ • G PRO K/DA • G502 Hero K/DA • G733 K/DA • G840 K/DA • Oculus Quest 2 • Nintendo Switch (Rev. 2)
Laptop (Dell XPS 13):
Intel Core i7-1195G7 • Intel Iris Xe Graphics • 16GB LPDDR4x 4267MHz • 512GB M.2 PCIe NVMe SSD • 13.4" OLED 3.5K InfinityEdge Display (3456x2160, 400nit, touch).
Got any questions about my system or peripherals? Feel free to tag me (@bellabichon) and I'll be happy to give you my two cents.
PSA: Posting a PCPartPicker list with no explanation isn't helpful for first-time builders :)
https://linustechtips.com/topic/1293594-new-power-supply/#findComment-14389935
3 minutes ago, Hudson Griffin said:
So I just bought a new power supply from evga and put it in my system and it didn't work I think I got it defective because there is a pin missing on the ATX main connecter.
Would this be the problem?
No, that pin is always missing.
https://linustechtips.com/topic/1293594-new-power-supply/#findComment-14389939
