So currently I built a new PC from a build I saw changed motherboard and power supply cause I didnt need wifi on a board. Everything goes good it's all put together turns on everything lights up but no display. I try again and again and realized its problem is prob needs bios update even thought box says compatible I try over and over again flash bios doesnt work flashes 5 to 6 times and then solid red I have tried rewiring everything resetting everything CPU is in good and CPU debug led is on so it has to be bios update if anyone know how to help of suggestions I'm all ears and would be grateful to know any input you guys have specs at bottom.
https://linustechtips.com/topic/1293087-computer-posts-help/
bios update is not the problem. Make sure you have plugged the monitor on and that the cable is plugged in your 1070 sicne ryzen 5 3600 can not display anything.
@Diln
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14385876
Just now, Caroline said:
Should still boot even with the monitor plugged to the mobo, if there's no output then the port is a dummy.
well yes.
@Diln try without the gp and see if it boots.
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14385914
Have you done a CMOS reset?
Main Rig:-
Server:-
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14385929
@Diln
It is I used hdmi and display port on graphics card just no signal
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14385990
Odd that you went for 120mm aio since 60$ aircooler would have been better easily. Anyway is the aio mounted correctly? AIO header on the "aio_pump" header on the motherbaord and the fan is spinning? Try to remount the cooler and cpu and see if it helps
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14385998
Is the CPU power connector fully in? it should make a click sound
It is fully in and I just used this 1070 on old build it ports were just fine
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14386017
I plan on upgrading I  future it's just availability is low rn in CPU and GPU market rn. I've already taken cooler out and reset CPU multiple times I've reset ram GPU all my cords into motherboard power supply not sure what problem is but everything runs and I dont have another GPU to test if its it but it was working on my previous pc
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14386034
I can I was just hoping everything would work and I was just missing something no oins are bent no dirt anything
It can also be the motherboard. you should be suprised how easily it breaks. I had the same exact issue with different specs.
I send the motherboard for RMA. They told me that one copper coil for mthe motherboard was scratched and that iw hy it would not work.
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14386054
Oh really dam I can always ask a friend to try a motherboard and see if it helps but it doesnt prob will rma CPU and motherboard and try a different combo ik works
https://linustechtips.com/topic/1293087-computer-posts-help/#findComment-14386068
