“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1292755-help/#findComment-14383285
I use one from the brand Onn, just as good as big brands and says switch compatible right on the package
"onn. 128GB MicroSDXC Card with Adapter - Walmart.com - Walmart.com" https://www.walmart.com/ip/onn-128GB-MicroSDXC-Card-with-Adapter/772835319
                          Ryzen 5800X3D(Because who doesn't like a phat stack of cache?) GPU - 7700Xt
                                                           X470 Strix f gaming, 32GB Corsair vengeance, WD Blue 500GB NVME-WD Blue2TB HDD, 700watts EVGA Br
 ~Extra L3 cache is exciting, every time you load up a new game or program you never know what your going to get, will it perform like a 5700x or are we beating the 14900k today? 😅~
https://linustechtips.com/topic/1292755-help/#findComment-14383698
